headspace residual benzene in fat/oil matrixes-matrix effect
Posted: Mon Sep 02, 2024 8:59 am
Hi everybody,
I'm currently working on trace analysis of benzene in vegetable oils and animal-fat matrixes by GC-MS-Headspace. We have to reach an LOQ of 0.01 mg/kg.
In a NaCl-saturated aqueous solution the method works fine, but (as expected!) when we passe to a fat matrix (vegetable oil or animal fat) we obtain very bad results.
I already found an article where authors worked on vegetable oils for benzene analysis and they announced LOQ near our goal (so in theory it would be possible to improve our method!), but they didn't specify detailed incubation information for HS vials. I already sent a email bu no answer until now
Our conditions are:
5g of sample in a 22-ml HS vial are incubated in a GC-PAL system for 30 min at 75°C with shaking speed set at 300 rpm; after this, 1ml of headspace is injected in GC-MS with a DB-624 type column. The internal standard used is benzene-d5.
MS detector is set to SIM mode.
Do you have any ideas which coul help me to improve performances of this method, please?
Or maybe such a LOQ is unrealistic for this kind of matrix?
I thank you in advance for your valuable help!
Best regards,
Carmen
Our conditions are:
Best regards,
Carmen
