Shimadzu RID-10A connection to a Agilent 1200 GPC
Posted: Fri Aug 09, 2024 9:51 pm
by KaylaF
Hello all, I am trying to connect a Shimadzu RID-10A to an Agilent 1200 Series GPC system through a Agilent 35900E Series II dual channel interface using an analog cable and a remote cable. The Agilent 35900E Series unit connects to the computer through a LAN connection and is controlled by Chemstation software. Currently, I am able to read the RI signal on Chemstation, but I am not sure I have the remote connection set up correctly as the detector does not initiate when a sample is injected. Any help would be greatly appreciated. Thanks!
