HELP REPLACING ICPMS QUICK COUPLING CONNECTORS
Posted: Fri Aug 09, 2024 9:34 pm
Hello, I write here as a last resource. I need to replace the quick coupling connectors of the water manifold that chills the spray chamber Peltier of a ICP-MS 7500cx from Agilent. I contacted the official service to no avail, the equipment is obsolete and they refuse to provide assitance.
I would like to open the panel and replace the female connectors myself, can anyone give me a tip or two to do that? Or maybe someone who knows?
There are no visible screws. Maybe dismantling other part can give easy access. I tried accessing the female connector from the back cover, but is complicated since there are other electrical parrts there and it would imply to dismantle a lot of components.
I have pictures if anyone needs
Thank you very much in advance
Best regards
Pablo Y.
Best regards
Pablo Y.
