Waters Acquity UPLC QSM Erratic Pressure Troubleshooting
Posted: Wed Jul 24, 2024 6:36 pm
Hi All,
I had this happen to me twice lately. I would appreciate if you guys/gals help me pinpoint where the issue exactly is. I am somewhat comfortable performing my own fix, but do not want to dissassemble everything without knowing what might be wrong with the system.
https://imgur.com/a/5O5W3Cp
Above image shows a sudden loss in pressure and subsequent stuttering.
I am suspecting a primary pump check valve failure.
I am positive that there are:
1) No leaks from pump heads
2) No air trapped in the system
3) Nothing wrong with the column
Thanks in advance!
Thanks in advance!
