Problems with the FlexCube module
Posted: Tue Jul 16, 2024 6:50 am
Hello everyone, I am writing to this forum because I have a problem with an LC-MS, specifically with a FlexCube module. The equipment is a 6410 and the Flexi module model is a G4227A 1290 FlexCube, which has 2 SPE online cartridges. The problem is that with each injection that the equipment makes, the pressure increases by 3 to 5 bars. As a result, at the end of a sequence, the pressure has increased by 100 bars compared to the initial pressure. Also, when the pressure increases so much, the peaks start to become deformed and the column is damaged. And if you try another method that does not use the FlexCube, the pressure remains stable, but for this type of samples we need to use the cartridges.
All the parts of the module and the capillaries have been replaced and we do not know what else to try.
Thank you.
Thank you.
