HELP: SE-HPLC of PEGylated lysozyme
Posted: Fri Jul 12, 2024 1:42 pm
Hello everyone,
I have been struggling with my SE-HPLC for over a week now and definitely need some help. I am trying to characterize PEGylated lysozyme with varying molecular weights of PEG on an Agilent AdvanceBio 300A, 2.7um, 300mm, ID 7.8mm column. The column is old but had eluted the compounds fine once with a mobile phase of 100mM NaCl and 25mM phosphate buffer. The next time I eluted these compounds using this buffer, the tailing of the peaks and retention time became much longer and so I did a cleaning of the column with an acidic buffer which improved it marginally however it was still severe enough that I decided to try other mobile phases.
I have trialled two other mobile phases now including 100mM sodium sulfate/100mM PB and 25mM PB/300mM NaCl. The story is the same for both of these mobile phases: The native lysozyme elutes fine but the conjugants do not elute at all and I get no peaks.
Has anyone done similar characterisation and can advise me on this? Is there more troubleshooting I can do or is it just a matter of buying a new column? I trialled two columns for this and the results were the same; although they were both old columns.
Thanks.
Thanks.
