Does 0.1 M sodium acetate dissolves in acetonitrile?
Posted: Fri Feb 05, 2010 3:44 am
Hi, everyone!
Could anyone explain me how to prepare 0.1 M sodium acetate in acetonitrile?
The protocol calls for
solvent A: 0.1 M sodium acetate and 0.1 M acetic acid in water (pH 8 );
solvent B: 0.1 M sodium acetate and 0.1 M acetic acid in acetonitrile.
I made solvent A with no problems. Then I started with solvent B. I added acetic acid to acetonitrile. So far so good. Then I added sodium acetate. Well, it did not dissolve... at all...
Could you please anyone tell me if I am doing something wrong or if there is an error in the protocol I am using?
