GC Mass : Molecular ion peak issue in EI mode
Posted: Tue Jun 18, 2024 11:04 am
Dear All,
I am working on analysis of a compound which is having the chlorine in the molecule and also having dichloro impurity. (Molecular mass is more than 150 and boiling point is more than 20
when i am doing GC MS on EI mode of that sample i am not getting the Molecular ion peak properly (the intensities of that is less than o.1% of the base peak.)
i am bit surprise as in EI mode i saw this trend 1st time.
I know for molecular ion peak CI mode is more suitable as this one is soft ionization as compared to EI which is an hard ionization.
I dont have the CI mode currently so i tried it to increase the molecular ion peak by changing the Voltage from 70 Ev to varies up to 15EV but not getting success.
If anyone can help me to get the knowledge why this is happening and with the available EI source how i can get molecular ion peak atleast 5-10% of base peak.
Even the same work we did with bromine also instead of chlorine and in that also we have found the same results.
Now i need to understand why this is happened and what more we can do (Other than Volatge variation) to get the molecular ion peak up to some extent.
this will help us to get confidence over other impurities also which is available in the samples.
