Shimadzu GC17 with 2 injectors
Posted: Wed May 22, 2024 10:55 pm
by greg07
does anyone use this chromatograph with two injectors? My question is, is it possible to configure the device in such a way that the split setting is independent? Now when I make a change, e.g. split > split less, the change occurs for both injectors. After pressing the Split button and the down arrow, the SPL1>SPL LESS1>OFF1 and SPL2>SPL LESS2>OFF2 options do not appear, there is only SPL>SPL LESS>OFF and you can hear the click of both Split valves.
Regards
Greg
