changes in the area of blank peaks in the test chm.
Posted: Sat May 18, 2024 9:49 am
Dear all
In the analysis of pregabalin according to the pharmacopoeia BP2023 Method A, a peak is observed in the blank, which is also present in the chromatogram of test solution, but the area of this peak changes and becomes larger and smaller and does not match with the area of the blank peak.
I would appreciate it if you have any experience share with me.
*blank exactly is the mobile phase.
I really appreciate your suggestions
Regards
Azam
Regards
Azam
