Losartan Potassiun Tablets USP Monograph Test 1
Posted: Tue Apr 16, 2024 11:15 pm
Hi.
I am having some issues with the cromatographic system for Dissolution test
for Losartan Potassium Tablets.
Anybody has experience with this metohd?
I need to know the Retention time, Tailing, theoretical Plateau, height and width in order to compare with my results in differents brnads of HPLC (i'm having big differences y that parameters).
This is the chromatographic system:
Solution A: 0.1% v/v phosphoric acid in water
Mobile phase: Acetonitrile and Solution A (40:60)
Chromatographic system
(See Chromatography á621ñ, System Suitability.)
Mode: LC
Detector: UV 254 nm
Column: 4.0-mm × 25-cm; 5-μm packing L1
Column temperature: 35°
Flow rate: 1 mL/min
Injection volume: 20 μL
Run time: NLT 1.5 times the retention time of losartan
Thanks in advance
Mode: LC
Detector: UV 254 nm
Flow rate: 1 mL/min
Thanks in advance
