Win10 patches / Chemstation
Posted: Tue Apr 16, 2024 7:57 pm
We've been happily using ChemStation E02.02.1431 on a couple Windows 10 machines (and one Windows 11) for a couple years now.
We've started having issues in Spring of 2024 on three different instruments, each one run by a different computer.
Each PC has two network cards. There is a switch for each GC / MS / Computer set. The computer's other network card goes out to the company network and internet.
In the past, for some (not all) instruments, loading ChemStation only worked if you disabled the 2nd network, regardless of what you had the Interface Metric / Bind Order set at under Network Settings -> TCP/IP. One the software was loaded, there was no problem.
Now it seems that if the 2nd network is connected, running samples sometimes results in the software freezing after the injection is made. To recover, the PC, GC, and MS need to be restarted.
I don't know if this is related or not, but another system is doing a weird thing where it "cannot bring up GC." The only solution I've found is to change the settings in Agilent MSD Configuration to make it an offline instrument. Then I load the software, load and save my method, load and save the sequence table, shut it down and switch it back to Online mode.
Is anyone else having similar struggles?
