Agilent HPLC system - Chromatogram assessment
Posted: Tue Apr 16, 2024 3:04 pm
Here I am again with more questions.... We have an Agilent 1100 system with an RID detector. We are trying to build a solid calibration curve with good repeatability. We performed 5 injections of each calibration point but I am not getting good repeatability between each injection. I have attached some screenshots and am hoping someone can tell me if my baseline noise is expected or is way too high for what I am attempting. My samples are a 5% solution and the column/RID are running at 40C @ 1.4mL/min flow rate. 5ul injection (I have tried 10ul and 20ul injections and both produced some very ugly peaks). The column is a Waters Amino (NH2) Column, 125Å, 10 µm, 3.9 mm X 300mm with a 75% ACN/25% H2O mobile phase.
I really appreciate the help and direction... We are in this bad situation where the company purchased the instrument used for $5000 from a university and while it looks like everything is functioning/putting out good resolution, my manager and I do not have enough experience to know a few of the basic questions such as what to expect a baseline to look like on an RI detector? Prior to this position I held a position at another company that used a calcium column on a waters system and they functioned well enough to achieve results with a ~0.1% repeatability but with this instrument I am seeing swings of 2-5% between injections and I can't decide if we need to increase our sample concentration to get us away from the baseline or if the baseline itself looks bad/needs help. We unfortunately could not simply clone the system I am used to running because our outside customer produces mixes that have sugars that co-elute on a calcium column and this amino column was the only one I could find that would produce all of the peaks that they are wanting.
Link to some photos of my chromatograms/baseline noise...
https://imgur.com/a/DUK7wY5
Link to column
https://www.waters.com/nextgen/us/en/sh ... -1-pk.html
Link to the waters powerpoint that helped us make the decision on column/system settings
https://www.waters.com/webassets/cms/li ... foodjk.pdf
Link to column
