Agilent MSD 5975 difficult in adjusting coils
Posted: Fri Jan 26, 2024 9:09 pm
I am adjusting the coils of an Agilent 5975 MSD but cannot lower the voltages below 125 mv when working with mass 100.
Also, I am checking the test points as in the document:
https://www.google.com/url?sa=t&rct=j&q ... i=89978449
We leaked the foreline pump and have changed some parts, but still, I can see some oil in the pane, so I think the pump is not fully sealed.
Can somebody give me advice on the maintenance of the pump it is a Pfeiffer Duo2.5. I have all the parts for an overhaul.
I will try to reseal it. I have looked on the internet and they said that the first problem is the Vacuum so perhaps is there the problem. Also, I get 0.000 mTorr pressure in the display. It is not okay. As I have searched.
Will check the pump again. But can you give me some advice, please?
Adolfo Álvarez
Adolfo Álvarez
