Isotope Ratio Measurements.
Posted: Thu Jan 18, 2024 3:08 am
Hello!
Feel free to tell me to remove the post as it relates to ICP-MS, but I was curious if anyone had a good document or source on isotope ratio measurements? I've been asked to collaborate on a project doing these types of measurements and never have before. We're looking to analyze water and wood samples for carbon isotopes.
I found this article that uses our instrument, a Perkin Elmer NexION2000 with Syngistix software.
https://resources.perkinelmer.com/lab-s ... ratios.pdf
I've done some research and know that you need to use isotopically certified standards, and that quad ICP-MS systems don't have as good of precision as MC-ICP-MS, but that's as far as I've gotten. The screen of our software's isotope ratio method editor is below (differs from the boron paper just for demonstration):
I guess I'm just confused on what the reference mass is (maybe from the isotopically certified standard) and the corrections? I know about mass bias from reading but not actual experience. Also, would I just select the other isotope I'm interested in and use the same reference mass and corrections?
The whole project only came about because word got around that I repaired our mass spec (LC-MS, QQQ and posted about in here actually) - we historically have never had one here, and then received the ICP-MS as a non-recurring budget request.
Thank you to anyone who can take the time to help!
