Severe drop in sensitivity after replacing ECDs
Posted: Wed Jan 17, 2024 4:26 pm
I am analyzing pesticides by GC-ECD, two columns and detectors (Agilent 6890N) and last spring one of our ECDs was leaking so we replaced both ECDs on the instrument.
Prior to the ECD replacement, the method worked very reliably. My 10 ppb calibrator for toxaphene gave a response of ~ 2000. Also, my endrin breakdown after inlet maintenance was always <5%.
Now, after installing the new ECDs, the response has dropped. The 10 ppb toxaphene calibrator gives a response of ~250, which is not much higher than my background. The change is the same on both columns and detectors. Also, now the lowest I can get my endrin breakdown is 12%.
I have been struggling to figure out what the issue is. I have gone over the detector installation instructions. I have tried replacing pretty much every part on the GC, redone all of the connections. I've cleaned the inlet weldment. It seems strange that brand new ECDs would really perform that poorly, and I don't see how changing the detector would have impacted breakdown. It seems like it has to be some stupid little thing that I'm overlooking.
Does anyone have a suggestion? I would really appreciate any advice!
