HPLC Nucleodur C-18 Degradation
Posted: Wed Jan 10, 2024 7:59 am
by Loys74
Hi all,
I have a problem with a column degradation and the problem come from the eluant which is Methanol / water / pH 6 buffer solution : 250 / 500 / 250.
After 200 injection all my peaks are splitted.
Pressure is stable (200bars), I work in isocratic mode, column is Nuclesosil 100-C18 5um, 125mm, 4.6mm and injection volume is 10ul.
When my column split my peaks, I can return it and work 20 injections.
DO you have idea?
PS: it is my first post
Re: HPLC Nucleodur C-18 Degradation
Posted: Wed Jan 10, 2024 1:29 pm
by DR
1) what is your buffer?
2) by "return", do you mean you turn it around - install it backwards?
3) what kind of samples are you running and how concentrated are they?
4) Have you tried a "clean out" gradient (run isocratically to collect your data, then increase the methanol concentration to flush the column, then back to your isocratic conditions)?
Posted: Thu Jan 11, 2024 9:59 am
by Loys74
Thanks for answering!
1) Buffer is pH6 (phosphate)
2) Yes we connect the column in the wrong way and sometimes (30%), we can use the column more time than in the good way.
3) We try to add cleanup with MeOH/Water (80/20) between injection without good effect and also try to add 1hour cleaning column with MeOH/Water 20/80 and 1 hour MeOH/Water 80/20 without good effect.
Thanks!
Posted: Thu Jan 11, 2024 10:19 pm
by Hollow
even you say the pressure is stable but for me this sounds like microbial contamination and partial restriction of the inlet frit.
- How good is your water purity?
- Do you filter your buffer with 0.2µm and keeping the bottle really closed by dedicated caps or just are they just capped with the old fashioned caps?
- How old is the buffer, how often do you replace it, incl. cleaning of the bottle (not just filling up the used bottle)
- How do you perform the isocratic mixing? Online or is the eluent premixed in the bottle? Premixing may be superior in that 25% MeOH may prevent/slow down the microbial growth.
- the use of a precolumn/crude catcher/inline filter may be indicated, where you change the cartdridge about every 180 injection (if the issue is correlated to the numbers of injections)
- try to clean your system with some strong solvents and replace the bottle sinker frits.
