Needle Tip Type for Prepping Vials for DGA
Posted: Fri Jan 05, 2024 5:58 pm
I am currently in the process of purchasing materials for a new lab that will conduct tests on Transformer Oil. To prepare the vials for headspace sampling (DGA), the standard (ASTM D3612C) requires the use of 18G1 and 26G1/2 needles. What type of needle tip would be best for this application? Thank you.
