how can I import data from MassHunter to chromeleon?
Posted: Tue Dec 12, 2023 11:18 am
by SamSamson
Dear all,
Is it possible to load chromatographic records from Agilent GCMS made with MassHunter software into chromeleon? I tried to export data from MassHunter to AIA format and then import them into chromeleon, but the following error occurred:
The netCDF files does not comply with the AIA chromatography data standard specification.
Thak you
Re: how can I import data from MassHunter to chromeleon?
Posted: Mon Jan 08, 2024 6:36 am
by antonk
Not sure hot if Chromeleon makes difference between two AIA specifications
for GC ASTM E1947-98 and MS data ASTM E2077-00.
Our UniChrom does.
https://www.unichrom.com/matrix-mse.shtml
