Thymidine ionization on a triple quad with ESI.
Posted: Sat Dec 09, 2023 12:22 pm
Hello!
My last post led me to great success, so I hope this one can too.
I am attempting to optimize our mass spec (Thermo TSQ Quantum Ultra with positive mode HESI) for the detection of thymidine, but my initial attempts showed nada in the TIC. I had a solution made up of 1:1 H2O:MeOH + 0.1% formic (their LC mobile phase will be ammonium acetate, pH 5.6 with acetic acid and I plan on trying with it on Monday). I was curious if anyone can give me any pointers? Most of the papers I've seen mention MRM, but I don't think anything but a full scan is desired by the colleagues I'm working with.
Here are the spectra I was able to obtain with direct infusion of the samples:
Each analyte was ~100 ppm to give great initial signal. I also tried uracil and uridine, for example, and wasn't able to see them either. The sample labeled by my grad student as "madmix" contained all of the analyes in one where we only observe dC.
I did try to vary my source conditions. The source was held at positive polarity and using our software's optimization feature (TuneMaster) we examined:
spray voltage (optimium was around 4.9 kV).
Sheath gas (optimum was around 14).
Aux (drying gas on our system) was hit or miss but for most of the analytes 0 gave the highest intensity.
Tube lens (I can't recall its optimum at the moment)
Cappilary offset was also examined.
The parameters that weren't examined were the vaporizer temperature (ours is set to be ambient at the moment as so far elevated temps made the spectra look awful, but I do plan on examining it on Monday), and capillary temperature (ours is maintained at 350, I plan on examining it also on Monday).
I'll close by fully disclosing I am in no way a biochemist. I avoided it (sadly) like the plague in grad school.
Thanks to anyone that reads this!
