carryover
Posted: Wed Dec 06, 2023 2:17 pm
Hello Everybody;
how are you today? I hope you are doing well.
since some time we have problem with quetiapine carry-over. Due to the need to analyze impurities in quetiapine which is our API, we must achieve a very low LLOQ. unfortunately, quetiapine shows high carry-over between samples and affects the attenuation of the signal of contamination, which has a very similar retention time. The question is short: what should we rinse the LC-MS/MS system with to get rid of quetiapine? any suggestion is very welcome .
