simuate distillation in HP/Agilent 5890 GC
Posted: Wed Nov 29, 2023 3:24 pm
by Analisis
Hello we have an hp/agilent GC 5890 with FID we want to make simulate distillation. What should I use for it?
Thank you
Re: simuate distillation in HP/Agilent 5890 GC
Posted: Mon Oct 21, 2024 2:46 am
by linda68
To perform simulated distillation (SimDist) using your HP/Agilent GC 5890 with a Flame Ionization Detector (FID), you’ll need the right setup, including specific hardware, columns, and software that support this analytical method. Simulated distillation is commonly used in the petroleum industry to simulate the distillation of hydrocarbons by separating them based on their boiling points. Emoji Kitchen
Posted: Mon Oct 21, 2024 6:38 am
by antonk
Here is an example of SimDIS system on HP-5890 https://www.unichrom.com/simdis/simdise.shtml
Packed inlet or CoC, 10-15m simDis column, FID
Posted: Tue Oct 22, 2024 7:50 am
by Loisugre
drift boss
Choose a liquid sample that you want to analyze. Ensure it's suitable for GC analysis.
Posted: Fri Nov 08, 2024 10:18 pm
by AICMM
Analisis,
MoGas or Diesel or crude? Columns change and hardware should change accordingly. Split possible for Mogas, COC recommended for DSL and crude, columns will change accordingly. How do you intend to process the chromatogram that you will obtain since I think that is certainly the most challenging part.
Best regards,
aicmm
