% Relative percentage difference
Posted: Fri Nov 24, 2023 11:32 am
by snisyriou
Hello!
Which is generally the acceptable % RPD between two measurements of the same sample? Can it be greater between low level results?
thank you in advance
Re: % Relative percentage difference
Posted: Fri Nov 24, 2023 3:43 pm
by vmu
The general acceptance limit does not exist. The limit depends on your task.
Usually it is the case.
