Shimadzu GCMS autotune failing 502 intensity
Posted: Wed Nov 22, 2023 3:14 pm
by Drew.Brees
I have a GCMS=QP2020NX from shimadzu that started failing a 502 check after changing the column. I cleaned the source, changed the filaments, cleaned the lens stack, cleaned the rods. Still nothing.
Any ideas?
Re: Shimadzu GCMS autotune failing 502 intensity
Posted: Sun Nov 26, 2023 10:12 am
by antonk
Any ideas?
Revert older column
Posted: Mon Dec 04, 2023 1:57 pm
by hcs
Check the position of the column at the ion source. It is sensitive to the geometry.
