anion exchange column
Posted: Mon Feb 01, 2010 8:46 am
by jithendran
I had been using tris buffer and sodium phosphate buffers at ph 7.9 on my anion exchange column. I could see few clear peaks in blank runs ie with out any sample injection. I strongly suspect the reagents as we ruled out the chances of involvement of the column or LC system in this problem. Previously I was using reagents sodium phosphate and tris from other brand, I tried your 99.9% trizma. Now the peak area and peak numbers have come down, but still could see clear peaks. Can I ask you if you have come across such a problem asked to you before and if do you have a better grade tris and Nacl (in eluting buffer) with possible little impurities that are not picked up by anion exchangers.
Posted: Mon Feb 01, 2010 9:11 am
by danko
Have you dismissed the possibility of contaminated water?
Posted: Tue Feb 02, 2010 9:36 am
by jithendran
Thank you for replying. Do you think its because of nucleotide materials in water? I did try to check the spectrum of milliQ purified water I use. It did not show me any contamination at 250-260nm wave length. The problem is I use the water from same sort of purifier (milliQ - brand) to blank the uv spec. Is there an other way to check it.
regards,
jith
Posted: Tue Feb 02, 2010 11:14 am
by danko
Yes! Just use the water instead of eluent A. Then run the gradient program once with the normal equilibration time, then equilibrate for much longer (3 – 4 times the normal) and run the gradient again. You should not inject anything – just zero mL.
If it’s the water you’ll get much larger peaks when running the gradient following the longer equilibration time.
Posted: Tue Feb 09, 2010 1:17 pm
by jithendran
Hi there,
I did long equillibriation buffer A, the ghost peak signal increases with increase in equillibriation time. I will do the same with water, thank you very much again.
jith
