Negative peaks
Posted: Wed Dec 22, 2004 1:37 am
Can anyone advise on why we get negative peaks on our solvent front with a reverse phase assay method when the sample solvent is mobile phase. Wavelength is 210nm and mobile phase is 0.4% THF, 1.0% Isopropyl Alcohol, 98.6% water plus TFA to pH 2.6
Is it the TFA that causes this problem ?.
Any hints would be appreciated. Thanks.
Sarex
Sarex
