effect of column length on pressure
Posted: Tue Jan 26, 2010 6:48 pm
I was using 19x100mm 5 micron C18 waterxbridge column with 10ml/min, even with 100% water backpressure was 1000 psi.
i just bought another 19x250 mm ,5 micron, C18 Waterxbridge column..back pressure is more than 4000psi( my pump maximum limit) with 95% H20:5% ACN 10ml/min flowrate.
I can not use it now cause most of my method need 95% aqueous as starting gradient. Why the backpressure is so high? i thought it would be around 2500 psi with 100% water before I bought it. In the papers they sent with column they have used 80:20 ACN:water with 16ml/min flow rate and reported backpressure was only 1000 psi.
Can somebody explain me why the back pressure is so high when the colum lengght is only 2.5 time more.
please help
please help
