Chromeleon/Dionex question
Posted: Mon Jan 25, 2010 5:59 pm
by djaydearz
Does anyone know how to bring the PDA signal up on the screen just whilst the pump is on, so you can see it settled before starting a sequence run. At the moment, you can not observe any signal (a black line) until you have pressed start.
Cheers
Posted: Mon Jan 25, 2010 8:49 pm
by yokes
The blue circle on the top bar, 3 positions over from the question mark. It toggles Acquisition On/Off. Then a pop-up appears asking what channels to aquire.
Hope that helps.
E
Posted: Thu Jan 28, 2010 7:41 pm
by Jiri Urban
thanks, otherwise I would porbably use Status task bar with Acq On/Off button forever ;-)
