Detection of Hydrogen
Posted: Thu Jan 21, 2010 4:02 pm
Hi again
Since u could help me the last time, i want to ask u about the best conditions for the detection of hydrogen.
At the moment i use the following conditions:
Column Temp.: 150°C
Column Flow: 30 mL/min
when i have concentrations lower than 0.01 vol% of H2 its impossible to destinguish between the background noise and the hydrogen peak.
may be u have some ideas of how to reduce the background noise and how to increase the h2 peak, respectively.
that would be great!!!
thank you!
here are some more details:
Detection mode: TCD
carrier gas: Nitrogen
my injection volume is usually 200µl.
here are the informations about the column:
Name: RT-Msieve 5A, Thickness: 10 µm, Lenght: 30 m, Diameter: 0.53 nm
The GC i'm using: GCMS-QP2010 Series (by Shimadzu)
Column Temp.: 150°C
thank you!
Detection mode: TCD
