HPLC
Posted: Wed Jan 20, 2010 4:13 pm
Hi! my name is Pamela Arias. I am trying to validate a method to analyze aminoacids in foods by HPLC.
Right now I am injecting standard solutions of diferents aminoacids, and I dont know why the peaks dont appear. I have tried changing diferents variables but it doesnt work.
I am using 2 buffer solutions:
A: sodium acetate trihydrate + triethylamine + EDTA + pH=7.2 + tetrahydrofuran
B: sodium acetate trihydrate diluted + pH= 7.2 + methanol + acetonitrile
I am using a stock solution of OPA (50 uL) + Borate (250 uL) + sample (50 uL) + FMOC (50 uL) and I am injecting 100 uL.
Everything is microfiltered before to inject.
The column C18 I am employing is 25 cms.
I am using a flow gradient for the buffer solutions like this:
Time (min)= 0,17,19.5,20,24,24.5,25
%B= 0,60,100,100,100,100,0
Flow(mL/min)= 0.8,0.8,0.8,1.3,1.3,0.8,0.8
The detectors I am using are UV (338nm) and FLD (340 - 450nm)
I dont know why I am doing wrong, this is my thesis of pregrade. I am in the last semester of chemistry in the University of Antioquia in Medellin-Colombia. If you know something that I can do to improvement my method, I would be very grateful.
Thanks.
Thanks.
