Chemstation macros
Posted: Tue Oct 17, 2023 2:10 pm
We have a macro to process 8890 FID's in chemstation. It requires generating a percent report. On one instrument, it will process the report through the method first, but on another it runs the data analysis macro first, which errors out with the percent report not generated. Is there a command to write in the macro to generate the report??
