Can I use an Agilent 5973 EI ion source in a 5977?
Posted: Sun Oct 15, 2023 6:01 pm
I had a 5973 analyzer repaired, and it tuned fine when they did the work. I drove it back myself to avoid shipping, but now that I have it set up, the tune is bad.
I cleaned the source (the tech said it may have oxidized if I heated the source too soon after pump down), the vacuum is good, pftba good, tried old default tune, nothing.
They keep telling me it's the source. Can I test this source in a 5977 to eliminate that as the issue?
