theoretical question band broadening
Posted: Tue Sep 12, 2023 7:46 pm
there is somting I do not understand:
During an analysis the different components of the sample are all an equal amount of time in the liquid phase. And they differ in the retention time because they are different times in the stationary phase. The band broadening due to longitudinal diffusion should therefor be the same for each component if the diffusion coefficient is the same. The peaks however get broader at the end of the chromatogram....
What is the explanation for this??
kind regards,
Papatom
kind regards,
Papatom
