Ramped flow rate affect peak area?
Posted: Wed Jan 13, 2010 6:43 pm
So, I've created a decent generic method to scan through most of my company's raw materials. However, we order denatured alcohol in two flavors: methanol free and the other contains methanol. They want to make sure the methanol free stuff really has no methanol in it.
My current method did not resolve the peaks between methanol and ethanol, so I lowered initial temperature, lowered the temp. ramp a few minutes and lowered the column flow. After this point, though, there's no need for such extreme separation and I'd like to speed up the method. However, I'm unsure about what affects changing the flow would have on peak area. From what I understand, the peaks are determined as the concentration of vapor-phase product in the carrier gas.
So, I'm torn; the flow over the detector is constant, so the concentration here should be unaffected. However, the flow rate of the column changes, so... yea, I am confused. Please, shed some light.
Thanks!
Thanks!
