HP 5890 Series II dumpster find
Posted: Mon Aug 07, 2023 8:42 am
by wss
I've just acquired an old HP 5890 Series II, which is pretty worn and will probably just be used for spares if I get another one, but I'm vaguely thinking of trying to get it going. It appears to have an FID installed with some bits missing but I might have spares somewhere in my lab at work.
I'm not very familiar with the 5890, having only used 6890s and 7890s and then mainly with 5975/5977 MSDs, but I was wondering what might be the best version of Chemstation to use with it? I'm not sure when Agilent stopped supporting these units. I have a few GP-IB PC cards and enough PCs of a suitable vintage, and it doesn't need to connect to a network or anything so anything from Windows 3.1 onwards is a go. Is it worth getting it going? Even just to do something like TPH or alcohols or something similar.
Re: HP 5890 Series II dumpster find
Posted: Mon Aug 07, 2023 7:40 pm
by rb6banjo
I'm still using a 5890 Series II (HPIB data communications). It's running Win95 and Chemstation Rev A.06.01 [403].
I have Win95 on floppies but I don't have the Chemstation software because I inherited it from another lab, years ago. If the PC fails, I'm pretty much in trouble on that instrument. I recently had the FID detector board die. I found one on Ebay and I was back in business for ~$50.
It's still a very reliable instrument. I think mostly I'm at risk if the PC fails. I doubt I'll be able to find another like it.
Posted: Tue Aug 08, 2023 3:04 pm
by KM-USA
I'm retired now, we had several 5890 units, really great instruments.
For your unit, I would suggest A.06.03 for which I can supply software by E-mail if you post your E-mail address (such as in form abc at 123 dot com). You would need to use your own Agilent license number.
I can also supply replacement media for A.07, A.08, A.09, and A.10 but the differences in those are primarily for the version of Windows one uses.
Posted: Tue Aug 08, 2023 10:10 pm
by wss
Thanks! I think I have a licence for A series Chemstation lying around somewhere. My email address is wss [dot] ion [dot] trap [at] gmail [dot] com.
I have some old GP-IB ISA cards in storage somewhere, but I've never actually used instruments with GP-IB, only over LANs. Does the 5890 II and Chemstation require a specific HP-branded HP-IB card (such as an 82341) or would other branded cards work if I have the drivers?
Posted: Thu Aug 10, 2023 7:24 am
by antonk
Our UniChrom supports 5890 all flavours for Windows/Linux
General info about communication boards
https://www.unichrom.com/hpx890/hpx890e.shtml
Download
https://www.unichrom.com/chrom/ucdle.php
Demo mode allows 3 min of online data collection for testing
Posted: Thu Aug 10, 2023 12:52 pm
by KM-USA
I am not computer literate enough to answer your question. The older computers used an 82335 board and the "newer" ones 82341 or 82350.
I will try to send A.06.03 electronically later today to your E-mail; you can edit out/delete the E-mail address from your earlier post if you wish.
Posted: Thu Aug 10, 2023 1:05 pm
by antonk
82335 (ISA) would work only for win9x and Linux, it uses memory mapping.
82341 (ISA), 82350 (PCI) would work under all NT platforms and Linux too
Posted: Sun Aug 13, 2023 2:09 am
by wss
I also have a few Agilent AGES1A RS-232 to LAN interfaces - we have loads of these surplus at work but I'm not sure what they were ever used for since we've never used RS-232 with any of our instruments. Does anyone know if I can interface to the 5890 Series II with one of these?
Posted: Mon Aug 14, 2023 6:36 am
by antonk
Terminal servers just map incoming TCP connection to serial port.
Like this https://www.unichrom.com/psw/xpswe.shtml
Terminal server serial port has to be configured to exact port rate of instrument.
Sometimes these port servers have virtual comp-port drivers. In such case software sets port rate at virtual com-port side, and the port-server side configures it's hardware serial to specified rate.
Posted: Wed Aug 16, 2023 6:48 pm
by James_Ball
If you have one of the MSDChemstation versions before I believe D.02 that will work also. I always ran the MSD software even on 5890 alone, just liked the interface and especially how it handles calibrations much better than the Chemstation A versions.
