Metrohm Calibration Curve
Posted: Thu Aug 03, 2023 7:28 pm
I am trying to build a calibration curve to run EPA 300.0. My analytes will be bromate, bromide, chlorate, chloride, chlorite, nitrate, nitrite, fluoride, phosphate, and sulfate. I am using a Metrohm 930 Compact IC Flex with sequential suppression, a Metrosep A Supp 7 250/4.0 column, Metrosep A Supp 16 Guard/4.0, and A Supp 7 eluent.
We analyze surface, ground, and drinking water. Our samples can sometimes range into the high 200s mg/L for chloride and sulfate. On our existing column (A Supp 5 150/4.0), the calibration ranges for chloride and sulfate max out at 100 mg/L, which seemed kind of low from what they can handle, but I have noticed matrix interference on nitrite when chloride gets above 200.
I'd appreciate any examples of curves others are running for EPA 300.0/300.1 that they've found success with using.
Thanks in advance for any guidance!
