Have a nice day! Did anyone have any opinion about following issue with the Waters Acquity system: I created a method, wrote a sequence in MassLynx 4.1, than I started sequence and no injection started. But my Synapt is started acquiring. Where could be the issue? Handle command for injection in method editor working properly...
Solved! Signal cabels on rear side of the instrument were an issue
Warm regards,
Azamat
