Internal standards for LC-MS (reverse phase)
Posted: Thu Jun 29, 2023 5:08 am
Hello!
I am trying to quantify the steroid acids using IS, on Agilent 1260, Q-TOF MS, C-18 column. I made a standard of docosanol (1 mg/ml in MeOH), but the peak was very low (I diluted it to 0.1 mg/ml, but still peak height has to be much higher). In addition, I found that the IS got solid after being stored in a refrigerator. I knew that the problem will appear, as melting point is even above room temperature.
Thus, I am wondering if there are internal standards that meet several requiements:
1. Highly soluble in MeOH, MeCN or water;
2. After being dissolved, keep liquid in room temperature;
3. Suitable for LC-MS.
4. Not pricy.
I realize that my attempt to use docosanol sounds strange, but my supervisor said that first I shall try to use existing supplies rarther than purchase something.
4. Not pricy.
