Prostar 218 Pumps
Posted: Fri Jun 16, 2023 5:33 pm
I am running a Varian 325 detector and two prostar 218 solvent delivery pumps with Chem Station.
One pump keeps leaking at pump head (25 mL SS) even after changing check valves and pump seal. Piston looks fine.
QUESTION 1: ideas?
QUESTION 2: can you use a single pump and get reproducible isocratic results? So far, this has not worked for me.
RELATED QUESTION 3: for 218 pumps, do you need to always use two pumps
QUESTION 1: ideas?
