We just got 4 new GC and GCMS 8890 systems from Agilent. No surprisingly, our custom macros and LIMS system developed 25 years ago do not work with either Mass Hunter or Chemstation F software. Which LIMS systems have you guys had success with using Mass Hunter or the newest iteration of Chemstation?
The organisation that I work for uses a custom (mostly) in house LIMS system. While it can directly and automatically import reports generated by MassHunter, the feature I more frequently use is manually importing data exported from MH or CS as *.csv files. It doesn't take long (about 20 seconds for a seasoned user) to format that csv data into the format required by our LIMS.
Surely your LIMS can directly import something like .csv? It's a common feature for testing purposes.
