Air/Water check, isotope ratio
Posted: Thu Jun 01, 2023 5:56 pm
I'm used to seeing air & water check results for a 5973 where 18 and 28 are both at about 0.5-2%
Lately I'm getting results that are too good: both are less than 0.1%
I'm also seeing isotope ratios that can't be right. I've seen as high as a 40% ratio of 19:18.
If I run a Standard Tune, it shows 18 and 28 at about 0.5%.
Any idea what's going on? A dirty source maybe, or an issue with mass assignments on the low end?
