Testing different salt concentrations for SEC-HPLC
Posted: Tue May 30, 2023 11:41 pm
I'd like to test different buffer composition, specifically different concentrations of salt used for SEC-HPLC for antibody analysis.
If my starting buffer is 50 mM Sodium Phosphate 300 mM Sodium Chloride pH 7.3, is there a way to change the gradient composition so that i dont need to make 8 different salt buffers?
Also, is PBS a buffer choice for SEC? why or why not?
thank you.
thank you.
