Observing negative peaks after cleaning GPC column
Posted: Sun May 07, 2023 11:15 pm
Cleaned GPC column with 50% acetonitrile, 50% MEOH, for 5 min in the reverse direction, and then an hour with the normal direction. But when I ran my samples, the peaks looked really weird.
Also, when running the samples, I stopped the run in between to add a sample. Is it possible that this could have affected the machine or introduced pressure issues?
