Chemical difference between two HPLC columns?
Posted: Wed Mar 29, 2023 2:14 pm
Please can someone explain the differences in the chemistry between these two HPLC columns:
Agilent ZORBAX RRHD Eclipse Plus C18 (50 mm x 2.1 mm, 1.8µm)
Waters Acquity UPLC BEH C18 column (50 mm × 2.1 mm, 1.7 μm)
I'm getting very little retention with the ZORBAX, even with 100% aqueous isocratic flow. I've seen some reports of others having success with the Acquity column, for the same compound as I'm developing a method for. I just want to understand the differences between these two columns before I buy one. Thank you.
