INSTRUMENT PRE RUN
Posted: Sat Feb 11, 2023 3:59 am
by nurfatinie
Dear all in reading,
Good day to you. Im Fatinie Chemist from Top Glove. Currently im in charge for Headspace GCFID.
Today when i want to run my samples, the GC instrument status turn pre run and its idle even if i load shutdown method.
I turn off the oven function at instrument and wait until the temperature decrease.
After that i load method again, after temperature increase, the status change o pre run.
Can anyone help me?
Thank You
Re: INSTRUMENT PRE RUN
Posted: Mon Feb 13, 2023 3:14 pm
by DR
How about including some more information, like brand/model of GC (as well as HS) and data system in use?
What you've provided is a little like "how do I get into my airb&b?" while failing to specify an address, type of lock and any directions provided by the renter.
