Standalone with HP 5890 II and 7673 Autosampler possible?
Posted: Wed Feb 01, 2023 9:27 am
is it possible to operate a HP 5890 II with 7673 in standalone mode completely without computer/integrator?
I'm trying to set up a GC taken from a former GC-MS system working with a PC over GPIB. It should now work as GC-FID together with the sampler but without a PC connected to it, just using the analogue output and an A/D converter.
I've read about the INET protocoll, but all examples are with either PC or integrator connected. The GC displays System Not Ready all the time. I can inject manually and press start, everything is working, but I want to use the sampler which has a standalone setting described in the handbook.
Has anyone running it this way?
Gerd
Gerd
