Turbomass
Posted: Thu Dec 08, 2022 10:09 am
Hi All
We had Clarus600 GC and MS system which using turbomass 5 software, It been off for more than 2 years and I was asked to used it again.
The PC is lost, so we manage to replace it with another PC with Windows 7 installed. I installed the Turbomass software on that PC
There are Ethernet cable connected from MS to GC, and there are another cable from GC to Computer (GC, MS, Connection pic).
Right now the Turbomass are unable to connect with MS and having error (Turbomass Error pic)
I try to manually configure the system, and success (Config Turbomass, Config Update pic). But still turbomass having the same error.
I check on the manual, and try to correct the GC to MS and PC Connection based on the manual (Manual pic) but also problem persist.
Any kind of advise will be highly appreciated. Thank you
Detail picture, can be find in this gdrive link https://drive.google.com/drive/folders/ ... share_link
