Maleic Anhydride GC Testing
Posted: Mon Jan 04, 2010 5:00 pm
I set up a GC test to check for a contaminant in a suspected lot of this material (maleic anhydride). Since it's a solid at room temperature, I dissolved 0.1g of maleic in 3 ml of acetone. The testing for the contaminant worked just fine this way and proved what was suspected. What is interesting is that if I take and do a norm% on the chromatograms, it looks like I may have a suitable maleic anhydride purity test in that these results also correlate well on several samples with the production problems.
I'm not convinced that the MA makes it through the inlet unscathed and certainly don't want to report erroneous results.
5 uL injection
split=10
inlet = 200C
TCD = 250C
30M x 530 x 1um wax
oven 50/5/5/200/1
Anyone with experience doing anhydrides directly without derivation?
5 uL injection
split=10
inlet = 200C
TCD = 250C
30M x 530 x 1um wax
oven 50/5/5/200/1
