[Chromeleon] SEC Integration
Posted: Tue Dec 22, 2009 12:32 pm
Hello All, it's me again.
And I have another Chromeleon question. This time about integration of SEC chromatograms.
I run a separation of proteins and peptides on a TSK Biogel column. The result is your typical SEC chrom. A range of overlapping peaks and plateaus, which is no problem, because that is what I expect.
The question is about integration of this. I'm interested in the Area% of a couple of molecular weight ranges. Through a set of standards I have calculated what the Rt's are of different mw's like 10KDa, 5KDa etc. And I want to know the Area% of let's say from 10KDa to 5KDa.
What I do now is manually split the peaks at specific times for the whol chromatogram, but I want to know if there is a way to do this automatically? Which integration parameters should I use to do this?
Thanks again for your time and happy Holidays!
Maurice
Maurice
