please help , choosing column
Posted: Wed Dec 16, 2009 2:28 pm
Hi all
I am doing a research on biogas production, what is the suitable column for detecting biogas ( methane ,CO2 , trace of H2S , H2O ) and volatile fatty acid VFA (C:1-6 ) in wastewater
Knowing that the GC is GC sp-6890 has TCD and FID.
Packed column: 5% SE-30 chromsorbw Aw Dmcs Chromosorb 60-80 mesh Ф3mm × 1.5 m Stainless steel column, carrier gas N2, H2, air
Or Capillary column: column length 30m, inner diameter 0.0.53mm, film thickness 1.0um, stationary phase SE-54, the maximum temperature of 300 degrees)
or other ? can i detect both of them the same time , with the same column?
The biogas sample are in a gas meter (water replacement method) how can inject the sample in GC? Use needle or tedlar bag or …? How to inject gas phase sample in the GC injector?
thanks
thanks
